Bosch 5 Piece HSS-G Drill Bit Set (Hex Shank)
- Drill bits with 1/4" hex shanks
- Precision ground, 135° split point ensures a fast clean cut
- Ferrous and non ferrous metals, hard plastic and wood
- Supplied in a plastic case
- Sizes: 2, 3, 4, 5 and 6mm
Axminster Workshop 13 Piece High Speed Steel Ground Drill Bit SetFrom £7.28 £6.07
Precision ground, these HSS-G drill bits are suitable for ferrous and non ferrous metals, wood and hard plastic drilling. 1/4" hex shanks make them suitable for use with quick change bit holders etc. The 135° split point ensures a fast clean cut in steel as well as most ferrous and non ferrous metals and hard plastic. Supplied as a set of 5 in a plastic case, contains the following sizes: 2, 3, 4, 5 and 6mm.
EAN Barcode | 3165140395427 |
