Easy Wood Tools Mid-Size EASY HOLLOWERâ„¢ #2
109314
From £144.88 £120.73
1 Review
Low Stock - Ready to dispatch
  • Hollower #2; gently curved shaft to begin undercutting
  • 9.5mm x 19mm shaft provides 100mm reach
  • Carbide cutter keeps its edge many, many times longer than HSS
  • Rectangular section shaft improves stability and minimises chatter
  • No need to sharpen; simply rotate cutter to a fresh edge
  • American Maple handle with copper ferrule for strength
Hollow forms can be tricky, Easy Wood Tools hollowers make this branch of turning easier and safer. Turn hollow forms with confidence, Easy Hollowing tools are designed to give you access from just-under-the-rim to deep unseen cavities. Hollowing is as Easy as 1 - 2 - 3.
The Mid-size Easy Hollower #2 has a gently curved shaft allowing you to begin hollowing to the side and start undercutting. It comes fitted with a Solid Carbide cutting tip. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. When the edge eventually dulls; simply slacken the fixing screw and turn to a fresh edge. The 9.5mm deep by 19mm wide rectangular section shaft provides excellent stability and gives the #2 hollower a reach of 100mm.
The 355mm long handle is straight grained American Maple, with a copper ferrule for strength. The overall length is 546mm.
The shaft is engraved with the corresponding carbide cutter reference number.
5.00 1
