Festool DOMINO DF 700 Cross Anchor SV-QA D14
- SV-QA D14 cross anchor used to form corner/frame or butt joints
- Corners require SV-SA D14 split anchor and the SV-AB D14 anchor bolt
- Butt joints require SV-DB D14 double-headed bolt (SV-V optional)
- Other parts can be purchased separately
- Suitable for material thicknesses of 30mm or more
- Uses the DOMINO XL DF 700 to produce the joint
- Supplied in boxes of 32
The SV-QA D14 cross anchor combines with the SV-AB D14 anchor bolt and the SV-SA D14 split anchor to form corner or frame joints. Combined with the SV-DB D14 double-headed bolt and optional SV-V D14 widener if will form fast and strong butt joints, ideal for kitchen worktops. Other parts can be purchased separately.
The DOMINO connector revolution makes fast, accurate and powerful connections with the option of quick and easy disassembly and reassembly. The connector system for the DOMINO XL DF 700 joining machine is suitable for material thicknesses of 30mm or more.
Using the DOMINO XL DF 700 to produce the joint is an extremely quick process using only the machine’s stops or simple pencil markings. It requires no other accessories or templates. The finished joint is extremely stable. Cover caps are available in three colours for a high quality corner connection appearance. Supplied in boxes of 32.
