As with all other Mafell products, innovation and attention to detail are all there in the design and manufacture of this top quality jigsaw. Equipped with a Cuprex compact motor that delivers 900W of power and intelligent digital electronics to maintain speed under load. The P1 cc offers cutting depths up to 115mm. The base plate is compatible with Mafell F guide rail system for even greater cutting precision. The dust extraction uses the Venturi principle to maximise effectiveness and ensure the cut-line is free from debris at all times, even without attaching a vacuum extractor. The speed can be varied in a range from 800 to 3,000 strokes/min. With three oscillation settings and a zero setting, rapid progress in a wide variety of materials is assured.
The P1cc is compatible with Mafell Guide Rails and takes all standard bayonet fitting jigsaw blades, as well as the unique patented Mafell CUnex precision blades with a wedge shape design and extra strength.
Available as an optional extra is a special tilting base developed for exact bevel cutting ± 45°, this clips simply onto the machine replacing the standard base.
