PROXXON Precision Engineer’s Bit Set & 1/4" MICRO Ratchet - 36 Piece
108493
108493
From £39.98 £33.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Exceptional low profile, industrial quality, 1/4" hex ratchet
  • Plus 25 x 25mm bits, 9 x 80mm bits and magnetic holder
  • Packed in sturdy powder coated steel box
Anyone familiar with Proxxon Industrial products will know the quality is second to none. This 36-piece 1/4" hex bit set is no exception. Supplied in a sturdy, powder coated steel box, it comprises 34 bits, a magnetic bit holder for use in a power drill/driver and a special 1/4" MICRO bit ratchet.
The ratchet takes all 1/4" hex bits and features a magnetic insert. The compact head means the distance between reverse lever and bit end is only 30mm, giving access to confined areas. The 72 tooth ratchet transmits high torque. Made from CrV steel, double nickel plated with matte chrome plated finish, with an oil and acid-resistant TPR (Thermoplastic Rubber) grip. Total length 120mm.
The industrial quality bits are accurately formed and hardened for wear resistance
25mm long bits
TTX - 8, 9, 10, 15, 20, 25, 27, 30 & 40
Hex - 2, 2.5, 3, 4, 5, 6 & 8mm
XZN - 5, 6, & 8
Ph0, Ph1 & Ph2
Pz1 & Pz2
Slotted - 3.5mm
80mm long bits
TTX - 10, 15, 20, 25 & 30
Hex - 3, 4 & 5mm
Ph1
