UJK Vee Block for Drill Table & Fence
106699
106699
- A Vee block optional accessory for the UJK Drill Table and Fence
- Simply bolts into the table in place of the sacrificial plate
- Allows you to accurately drill round workpieces
- It has a centring hole for accurate placing for the drill bit
- A simple and worthwhile accessory
Show more
Show less
This Vee block is an optional accessory for the UJK Drill Table and Fence. It simply bolts into the table in place of the sacrificial plate. This block allows you to accurately drill round workpieces. It has a centring hole for accurate placing for the drill bit. A simple and worthwhile accessory. Size 115mm x 100mm.
EAN Barcode | 5052511120413 |
