Abrasive Belts For Bow Sander
- 50 × 915mm sanding belt for the Veritas Bow Sander
- Size ensures correct tension for effective sanding
- Move belt along as a section wears for full use
A 50 × 915mm sanding belt, to fit the Veritas Bow Sander. This size ensures the bow tensions the abrasive, firmly allowing the belt to flex and conform for effective sanding. By moving the belt along as a section wears, means you get full use of every millimetre of the abrasive making these particularly good value.
Abrasive Backing | Cloth |
Abrasive Belt Length | 915 mm |
Abrasive Belt Width | 50 mm |
