Arbortech HD Abrasive Discs 50mm (Pkt 20)
- For Arbortech Contour Sander, Mini TURBO Plane Kit, Mini Carver
- Designed for premium performance when power sanding
- Exceptionally long life, wide range of grits
- Cloth-backed abrasive unaffected by heat
These 50mm diameters, sanding discs extend the scope of the Arbortech Contour Sander, Arbortech Mini TURBO Plane Kit and the Mini Carver.
They are heavy-duty to withstand harsh conditions when power sanding. The cloth-backed abrasive, unaffected by heat generated during power sanding, has an exceptionally long life.
Supplied in packs of 20 discs of a single grit, ranging from very coarse 40 grit to extra fine 320 grit. Alternatively, there is a mixed pack containing 3 of each grit giving 21 discs in total.
