Earn extra with DOUBLE Points on all purchases!
Axcaliber Flush Trim Cutters Top Bearing
- Perfect cutter for template routing
- Bearing replaces need for guide bush
- Bearing diameter same as cutter diameter
- Greatly simplifies template making
- Precision made cutters on multi axis CNC machines
- PTFE coating helps minimise resin build-up
- 1/4"(6.35mm) shanks
Axcaliber Router Cutter Bearing - D=19 - X=6.35mmSpecial Price £1.34 £1.12 was £4.48 £3.73 Save £3.14 £2.62
Axcaliber Router Cutter Bearing - D=15.88 - X=6.35mmSpecial Price £1.34 £1.12 was £4.48 £3.73 Save £3.14 £2.62
These cutters have a bearing guide located on the shank, negating the need for a guide bush when following a template. The bearing is the exact same diameter as the cutter, simplifying the process when making a template. No calculations are necessary, as the workpiece will be an exact copy of the template.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
