Axcaliber Ripper 37 Bandsaw Blades
- Primary wood processing and ripping blade
- Exceptional cutting performance due to ground teeth
- Made from carbon rich European steel, induction hardened
- Re-sharpenable without losing performance
- Delivered ready for immediate use
- Recommended for bandsaws with motors of 2.2kW and above
- 31.75 mm blade width and 1.1tpi
The Axcaliber Ripper Blade 37 is specifically intended for wood processing and deep ripping tasks, fitting only a few larger machines where motors of sufficient capacity are able to handle the 31.75 mm wide blade. The teeth are precision ground using CNC machinery are then induction hardened. Furthermore, to ensure a very long working life, each blade can be re-sharpened up to100% more times than any other similar blade, offering the best possible cutting performance.
Bandsaw Blade Width | 31.75 mm (1.1/4") |
Model | Ripper 37 |
