PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The AP350WL features electronic variable speed enabling you to fine tune the speed to suit delicate work, larger diameters or out of balance work. A three step poly-V pulley system allows three speed ranges which coupled with the load sensing inverter ensure maximum torque and stable spindle speeds. The magnetic backed switch unit can be placed on any convenient position on the lathe bed or headstock. It incorporates on/off buttons, a speed control knob and forward and reverse switch. There is an LED digital read-out of the spindle speed in RPM. The swing over the bed is 350mm and with the extension fitted, the between centres measurement rises to 680mm. The spindle features 24 division indexing.
The lathe features an M33 x 3.5mm (ASR) spindle. All standard M33 x 3.5mm threaded chucks and fitments can be used as normal. The ASR spindle includes a safety groove. This is an additional safety feature designed to be used in conjunction with fitment with a matching ASR safety groove and a locking ring. This arrangement ensures complete safety when the lathe is running in reverse and is not necessary for general turning.
The addition of the floor stand means you won’t have to sacrifice precious bench space and can site the lathe anywhere in your workshop. The stand is adjustable in height from 610mm-875mm, enabling you to set it at a comfortable working height. The feet are splayed to give plenty of foot space, and fitted with rubber feet which are adjustable to accommodate an uneven workshop floor.
Supplied with four prong Axminster drive centre, Axminster revolving tailstock centre, 75mm faceplate and a knock-out bar.
Machine Classification
