Woodturning Fitments
  • Axminster Woodturning 4 Prong Drive Centre - 25mm Axminster Woodturning 4 Prong Drive Centre - 25mm
    This selects the Morse Taper of the variant Morse Taper
  • Axminster Woodturning 4 Prong Drive Centre - 9.5mm
  • Axminster Woodturning 4 Prong Drive Centre - 16mm Axminster Woodturning 4 Prong Drive Centre - 16mm
  • Axminster Woodturning Ring Friction Drive Axminster Woodturning Ring Friction Drive
  • Axminster Woodturning Ring & Centre Point Live Revolving Centre Axminster Woodturning Ring & Centre Point Live Revolving Centre
  • Axminster Morse Taper Arbor - JT6 to 2MT
  • Axminster Woodturning 4 Prong Jumbo Drive 38mm - 2MT Axminster Woodturning 4 Prong Jumbo Drive 38mm - 2MT
  • Axminster Woodturning Multi-Head Live Revolving Centres Axminster Woodturning Multi-Head Live Revolving Centres
  • Axminster Woodturning Mini Live Revolving Centre Axminster Woodturning Mini Live Revolving Centre
  • Axminster Woodturning Pen Mandrels Axminster Woodturning Pen Mandrels
  • Axminster Woodturning 60 Degree Live Revolving Centre Axminster Woodturning 60 Degree Live Revolving Centre
  • Axminster Woodturning 4 Prong Drive Centre - 27mm Parallel Axminster Woodturning 4 Prong Drive Centre - 27mm Parallel
  • Axminster Woodturning Faceplate 50mm - 3/4" x 16 tpi Axminster Woodturning Faceplate 50mm - 3/4" x 16 tpi
  • Axminster Woodturning Faceplate 75mm Axminster Woodturning Faceplate 75mm
  • Axminster Woodturning Faceplate 100mm - M33 x 3.5mm Axminster Woodturning Faceplate 100mm - M33 x 3.5mm
  • Axminster Woodturning Faceplate 150mm - M33 x 3.5mm Axminster Woodturning Faceplate 150mm - M33 x 3.5mm
  • Axminster Woodturning Lathe Mounted Polishing Mop Arbor Axminster Woodturning Lathe Mounted Polishing Mop Arbor
  • Axminster Woodturning Woodscrew Chuck 38mm - 1" x 8tpi
  • Axminster Woodturning Woodscrew Chuck 75mm - M33 x 3.5mm Axminster Woodturning Woodscrew Chuck 75mm - M33 x 3.5mm
  • Axminster Woodturning Light Pull Drive Axminster Woodturning Light Pull Drive
Woodturning fitments provide the essential components needed for mounting, adapting and securing accessories to your woodturning lathe. Including thread adaptors, inserts, drive centres, faceplate fittings and other mounting hardware, they help ensure compatibility between chucks, accessories and different lathe spindle sizes. Ideal for upgrading equipment, expanding workholding options and improving workshop flexibility, woodturning fitments are a practical addition to any turning setup. Browse the range to find woodturning fitments suited to your lathe and woodturning projects.
