Axminster Workshop AW355WL Woodturning Lathe - 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Cast iron bed headstock and tailstock ensure minimal vibration
- Powerful 750W DC motor, quiet and smooth operation
- Variable speed with spindle speeds from 250-3,550rpm
For those wanting to turn their hand to slightly larger projects...
Perfect for if you aim to turn larger projects, due to the increased capacity and optional mini bed extension which extends the distance between the centres even further.
Buy with confidence
So sure are we of the quality of this lathe, we cover all parts and labour free of charge for three years! Find out more
Variable speed drive
The variable speed control unit enables you to adjust the speed to suit your project; delicate work, larger diameters or out of balance work pieces. The LED digital read-out of the spindle speed in RPM, makes it easier to stay in control.
Motor
A 750 watt universal DC motor with electronic speed control and 3 speed pulley provides full torque at all speeds.
Great capacity with potential to increase
With 510mm between centres (depending on centres fitted) and a bowl turning capacity of 355mm, many ambitious projects can be undertaken. Plus, with the optional mini bed extension, you can increase your distance to 740mm. Image is shown with optional bed extension.
Cast iron construction
The cast iron construction ensures stability and reliability. The bed is made from cast iron, helping to reduce vibration.
Axminster Woodturning Pen Kits & Blanks PackageSpecial Price £19.98 £16.65 was £25.98 £21.65 Save £6.00 £5.00
The AW355WL is perfect for those woodturners looking to move up from a smaller lathe, or as a first lathe for the more ambitious newcomer. With a capacity of 510mm between centres (depending on the centres fitted) and with a bowl turning capacity of 355mm, many ambitious projects can be undertaken.
Made from grey cast iron, the stability and vibration absorbing properties will be much appreciated. Featuring a top quality DC brush motor, with variable speed, three belt ratios and reverse. It has a speed range to suit every project within its capacities. A spindle speed readout helps select the appropriate speed for the job.
The headstock has large bearings to support the spindle, a flip-up cover allows easy access to the multi-V belt for speed ratio changing. There is a 24-stop indexing facility, with a spring-loaded indent pin to hold the spindle into position. The spindle thread is M33 x 3.5, allowing many accessories to be fitted. It has a 2MT for centres.
Cam locks secure both the tailstock and tool rest holder, and both are easy to move along the bed.
Mounted on rubber feet and supplied with Axminster drive and tailstock centres, 200mm tool rest plus a 100mm faceplate.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Distance Between Centres | 510 mm |
EAN Barcode | 5052511124565 |
Headstock Taper | 2 MT |
Lathe Speed | 250 - 3,550 rpm (var) |
Max Diameter over Bed | 355 mm |
Model | AW355WL |
Nett Weight | 57 kg |
Overall L x W x H | 1,040 mm x 370 mm x 480 mm |
Power | 750 W |
Rating | Home Workshop |
Spindle Thread | M33 x 3.5 mm |
Tailstock Ram Travel | 70 mm |
Tailstock Taper | 2 MT |
Tool Post Diameter | 25.4 mm (1") |
Voltage | 230 V |
- Standard Delivery* - Free
