Axminster Workshop AW50E 50L Portable Dust Collector - 230V
- 63mm inlet, suits many common machines
- 2 stage filtration, removes 99% wood dust particles >1 micron
- 50L drum capacity
- Airflow: measured in our workshop 440m³/hr @ 63mm
The AW50E is designed as a dedicated alternative to using a domestic vacuum cleaner for extraction in a small home workshop. The 50 litre drum is 420mm diameter and at 730mm tall the AW50E takes up very little space. A neat solution to dealing with chips and dust. Fitted with a 2 stage filter comprising a cartridge filter and outer paper filter, it provides fine filtration removing 99% of particles greater than 1 micron. This machine has a 63mm inlet. The power head has a grab carrying handle and is fixed to the drum with a metal quick release strap.
Airflow: as measured in the Axminster workshop 440m³/hr @ 63mm.
Supplied with a spare set of carbon brushes for easy maintenance.
N.B. does not include an extraction hose.
N.B. Workshop machines used in a business education environment will be subject to a 1 year warranty.
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
Airflow | 440 m³/hr @ 63 mm (28-40 m/s) |
Container Volume | 50 litre |
EAN Barcode | 5052511125302 |
Filter Performance | 99% >1 micron |
Inlet | 63 mm |
Model | AW50E |
Nett Weight | 7.8 kg |
Overall L x W x H | 420 mm x 420 mm x 670mm |
Plug Fitted | UK 3 pin plug |
Power | 1.2 kW |
Rating | Home Workshop |
Sound Pressure Level LpA [Uncertainty K] | 85 dB(A) [1.5 dB] |
Static Pressure | 2,508 Pa |
Voltage | 230 V |
- Standard Delivery* - Free
