Axminster Workshop Garage Workbench
- Excellent value workbench for all uses
- Beech wood 30mm worktop and spruce legs
- Large 1,350mm x 500mm worktop
- Home assembly and finishing required
Axminster Woodturning Bigmouth Aluminium Dust PanSpecial Price £12.48 £10.40 was £15.58 £12.98 Save £3.10 £2.58
UJK Compact Multifunction WorkbenchSpecial Price £183.98 £153.32 was £229.98 £191.65 Save £46.00 £38.33
Stanley Metal Latch Toolbox 41cm (16in)From £14.08 £11.73
The Axminster Workshop Garage Workbench is a bench for everyone - woodworking or not - to have the space you need to get things done. If you have a garage or shed where you like to work on projects, but you're lacking an appropriate work surface, this is the one for you. The Garage Workbench has all the key features you need: a generous 1,350mm x 500mm working area, a sturdy 30mm bench top, a front vice, four bench dogs and a double row of dog holes (19mm), and a bottom shelf for storage. It is a combination of beech benchtop and spruce legs, which makes this an excellent value workbench. Ideal for: woodwork, carving, pyrography, restoration, DIY, modelling, and so much more.
In order to offer the best value with this bench, it comes as bare wood, which you can finish as desired. We recommend using an oil finish such as Osmo Top Oil or Chestnut Finishing Oil to protect the timber. Assembly is also required.
Dog Hole Size | 19 mm |
EAN Barcode | 5052511132898 |
Nett Weight | 35 kg |
Overall L x W x H | 1,350 mm x 650 mm x 850 mm |
Thickness of Top | 30 mm |
- Standard Delivery* - Free
