Sjöbergs Smart Vice
Sjöbergs Smart Vice
- Portable, simple and effective, for gluing, work holding, carving, crafts
- Simply clamps to practically any table top
- Includes 4 bench dogs for flat surface working
- 362mm wide vice, opens to 110mm
- Weight: 6.7 kg
This portable, go-anywhere vice gives you the option of fitting a large capacity vice on practically any table top or similar work surface using just a couple of clamps (not included). An ideal work holding solution for where space is tight or when out on site and with the benefit of being easily stowed away when not in use. Constructed by hand from a Birch laminate, this clamp holds work firmly in place, offering hands-free stable working.
Included with the vice are four dogs which provide even greater clamping possibilities. By placing the dogs on the top of the vice your work can be held on the flat, ideal for gluing up frames or planning of boards.
Made in Sweden using FSC-certified wood. Comes with a 10 year warranty. Practical, portable, space-saving and consciously made. Now that is smart!
N.B. A T20 key is included to help with assembly. Self assembly required.
| EAN Barcode | 7316703274109 |
| Jaw Opening | 110 mm |
| Jaw Width | 362 mm |
| Nett Weight | 6.7 kg |
- Standard Delivery* - Free
