Axminster Workshop No. 60.1/2 Classic Block Plane
109567
From £89.98 £74.98
6 Reviews
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
Please check Click & Collect in-store stock for availability.
  • One of the most useful planes in anyone’s kit
  • Low angle blade for super clean cuts
  • Excellent performance on end grain and softwood
  • Polished brass cap gives a little extra heft and comfort
  • Micro-adjustable depth of cut
Smaller than a bench plane but just as useful...
No 69 ½ Block Plane - predominantly utilised for evening, trimming and angling, the 60 ½ Block Plane is best suited to smaller project work.
Low angle
Bevel-up bedded at 13.5°, giving great performance especially on end grain and softwoods and is O1 for excellent edge retention.
Body
Ductile grey iron body, with a flat ground sole and low angle for general usage or end grain work.
Mouth
Adjustable mouth for fine or coarse work. The depth of the cut is controlled with a micro depth adjustment.
Cap iron
Polished, solid brass cap ensures the plane feels sturdy and comfortable in your hand.
  1. Axminster Workshop No. 60.1/2 Classic Block Plane
Total:
£127.37 £106.14
The Axminster Workshop No. 60.1/2 Classic Low Angle Block plane is a fine example of this popular model. Classic design with classic looks. The solid brass cast and polished cap gives the plane a comfortable hand feel with a little bit more heft. The blade is bevel-up bedded at 13.5°, for super clean cuts especially on end grain and soft woods. The blade is O1 steel, offering excellent edge retention. It comes with a 25° bevel. The blade only requires honing before use (putting a 30° micro bevel on the edge can be done in less than a minute).
The body is grey cast iron and features an adjustable mouth for fine or coarse work. The depth of the cut is controlled with a micro depth adjustment. The lateral blade ensures an even shaving. The sole is 155mm long with a 35mm wide blade.
A weight of 815g, combined with the low blade angle gives you a plane that is almost indispensable for most small trimming tasks.
4.20 6
