Bahco 625 Pocket Carbide Scraper - Triangular
810341
From £17.40 £14.50
8 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Designed for removing paint, glue, rust and varnish
  • 25mm triangular solid tungsten carbide blade, gives 3 edges
  • Aluminium body fitted with Polypropylene handle, Supplied with holster
  1. Bahco 625 Pocket Carbide Scraper - Triangular
Total:
£69.27 £57.72
A two component handle moulded onto strong aluminium body. Specially shaped with thumb rest for a better grip and comfort. The blades are solid tungsten carbide, they will last up to one hundred times longer than conventional steel blades. These tools find a use with woodworkers, restorers, boat builders and many others. The 625 is supplied with a holster and a 25mm triangular blade, giving three edges as well as the obvious sharp point. Also available for the 625 are three additional blades: 25mm circular, 22mm teardrop and 20mm pear shaped.
5.00 8
