Bahco Blades for 650 & 665 Carbide Scrapers
AX821761
AX821761
- Double-edged solid tungsten carbide blades
- Designed for removing paint, glue, rust and varnish
- Available in two lengths; 50mm or 65mm
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £12.38 £10.32 was £14.38 £11.98 Save £2.00 £1.67
Show more
Show less
These replaceable, twin edged blades last many times longer than conventional scraper blads. They are ideal for removing paint, glue, varnish and rust without the need for heat. The blades have convex ground edges to reduce the risk of scratching surfaces and cut on pull or push strokes. These tools find a use with woodworkers, restorers, boat builders and many others.
