Bahco Blades for 650 & 665 Carbide Scrapers
- Double-edged solid tungsten carbide blades
- Designed for removing paint, glue, rust and varnish
- Available in two lengths; 50mm or 65mm
These replaceable, twin edged blades last many times longer than conventional scraper blads. They are ideal for removing paint, glue, varnish and rust without the need for heat. The blades have convex ground edges to reduce the risk of scratching surfaces and cut on pull or push strokes. These tools find a use with woodworkers, restorers, boat builders and many others.
