Woodworking Wisdom
Building Your Dream Workshop, One UJK Tool at a Time
UJK Build your Dream Workshop
Tools That Earn Their Keep
Every maker has their most-reached-for tools, the ones you never realised were essential until you tried them. These compact, clever additions don’t take up much space, but they’re always on hand when you need them, earning their place again and again in your dream workshop.
UJK Compact Speed Squares
UJK Pencil
UJK Paint Points
UJK Compact Speed Square: Crafted from CNC‑machined aluminium, this compact square delivers pinpoint accuracy for marking, squaring, and angle checks, even in tight spaces
UJK Pencil: A bright, anti‑roll pencil with a sharpener built in. Ideal for crisp, visible lines on rough timber and compatible with UJK squares
UJK Paint Points: Aluminium paint stands that elevate workpieces for flawless brush access, no smudges, just clean edges every time
Crafting your dream Workshop
Establishing your dream workshop is more than just big, exciting machines (although they do help!). From UJK, they’re dependable tools that concentrate on solving the problem. Making your life easier, with no gimmicks, just practical performance.
UJK Saw Horses
UJK Pocket Hole Jig
UJK Pocket Hole Drill Bit
UJK Straight Router Cutters
UJK Bandsaw Buddy
UJK Sawhorses: Ideal for mobile setups or compact workshops, offering rock-solid support without compromising strength or set-up speed.
UJK Pocket Hole Jig: A precise, no-nonsense introduction to hidden joinery. Delivering strong, clean, hidden joints with minimal setup.
UJK Pocket Drill Bit with Replaceable Tips: This smart upgrade is designed for efficiency; this bit allows you to switch between three tip sizes without changing drills, whether they snap off, or you’re using multiple material thicknesses. Compatible with all pocket hole jigs.
UJK Straight Router Cutter: Designed, developed and manufactured in Britain, this cutter is built for modern routing demands. It offers cleaner cuts, improved safety, and extended edge life, ideal for precision joinery and repeatable results.
UJK Bandsaw Buddy: Take the guesswork out of bandsaw setup. This clever tool helps dial in blade tension, tracking, and fence alignment, making it easier to achieve accurate, consistent cuts every time.
Tools for Precision and Progress
You’ve been building, crafting, experimenting, and now you’re ready to hone those skills. UJK tools are here to help you take that next step with confidence. Designed for precision and ease, these tools work as hard as you do and grow with you, creating a dream workshop you can be proud of.
UJK Parf Guide
UJK Drill Guide
UJK Loose Tenon Router Cutter
UJK Parf MkII Guide System: The award-winning British-made Parf system helps woodworkers create custom benchtops, cutting boards, or MFT-style tops in under 30 minutes with a precise 20mm hole pattern, ensuring flawless 45° and 90° cuts.
UJK Drill Guide: Converts your hand drill into a near mini pillar drill. Perfect for dead-straight holes in awkward places or mobile setups.
UJK Loose Tenon Cutter: Create Domino-style biscuits in any material, any length, and in multiple sizes, all with just two cutters. Including custom Domino’s for exterior projects!
The Wish List
Now we can bring out the big hitters! These are the tools that don’t just help you work, they transform how you work. Built for professionals, dreamed about by everyone. Welcome to the UJK dream workshop.
UJK Dovetail Jig
UJK Router Lift Complete Package
UJK Parf Protractor
UJK Professional Router Table
UJK Universal Dovetail Jig: Precision-engineered in the UK, this versatile jig delivers six joint types straight out of the box. Whether you're building drawers, boxes, or cabinets, it’s your go-to for fast, accurate, and repeatable dovetail joinery.
UJK Router Lift Complete Package: Combining a powerful fixed motor with above-table height adjustment and precision control. Just pair it with a router table and you’re ready for high-accuracy routing.
UJK Parf Protractor: When you need to take the Parf even further, use it with the UJK Parf MkII Guide System to create custom benchtops with precise 20mm holes, at 90° angles in 5mm increments!
UJK Professional Router Table: The centrepiece of any precision workshop. With a rock-solid build, micro-adjustable fence, and seamless compatibility with the UJK Router Lift, this table is engineered for demanding routing tasks and long-term reliability.
Start Smart with UJK
Building your dream workshop starts with smart choices, and UJK tools are made for just that. Designed for precision, reliability, and long-term use, they help you set up and solve everyday workshop challenges easily. These are expertly engineered tools that help you work smarter from day one.
Leave a comment
