Bosch BiM Segmented Blades (Starlock)
- Cut wood and nails, veneered panels and plastic laminate
- Plastic, plasterboard and pipes
- Blades will cut flush to a surface
- Segmented to cut into edge or corner
- Blade width 100mm
- Starlock fitting for maximum power transfer
Bosch AIZ 32 EPC C-Tec HCS Plunge Cut Blades (Starlock) (Pkt 1)From £10.38 £8.65
Bosch BiM Plunge Cut Blades (Starlock)From £7.88 £6.57
Bosch BiM C-Tec Japanese Style Plunge Cut Blade (Starlock) 65mmFrom £16.78 £13.98
Wood and nails, veneered panels and plastic laminate this Bi-metal (BiM) segmented blade will give a long life. Blades will cut flush to a surface as well as into an edge or corner.
Suitable for Bosch, Makita and Fein (10mm) Multi-Tools and others using the Oscillating Interface System (OISâ„¢) or Starlock fitting which ensures a secure fit with maximum power transfer.
EAN Barcode | 3165140492379 |
- Standard Delivery* - £1.99
