This body only, GDR 18 V-160 professional impact driver is fully compatible with the Bosch range of 18V CoolPack batteries and chargers. This versatile tool has a robust construction coupled with excellent performance making it an ideal tool for a wide variety of trades. The driver features a 1/4" hex bit holder with a sprung loaded pullback sleeve ensuring your chosen bit is easy to change and always secure in use.
The GDR 18 V-160 offers an impressive 160Nm maximum torque, with variable speed control. The result is fast and easy work progress, even in heavy applications. The GDR 18 V-160 has an impressive bolt capacity up to M14. The ergonomic design features a slim handle, good balance and a compact 153mm front to back. The built-in LED job light illuminates your work in poorly lit situations. It comes with a handy belt clip and screwdriver bit. Supplied in a Bosch L-BOXX 136 storage case.
Compact, machine only 153mm front to back
Variable speed trigger with forward/reverse switch
Rubberised insert on handle for comfortable and secure grip
LED light illuminates the work area
Supplied as body only without batteries or charger
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
