WoodSpur Pozidrive Wood Screw Assortment (1,500 Pieces)
502478
From £29.98 £24.98
  5. Half Star
41 Reviews
  • Buy 5 for £28.48 £23.73 each and save 5%
  • Buy 10 for £26.98 £22.48 each and save 10%
  • Buy 15 for £25.48 £21.23 each and save 15%
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
Please check Click & Collect in-store stock for availability.
  • Top quality zinc plated wood screws with a self countersinking head
  • They have deep sharp threads that cut into the wood, not forcing through
  • Penetrating tip that requires no pilot hole or pre-drilling
  • Heat treated to ensure they are hard and resistant to snapping
  • For use in soft or hard wood, MDF or chipboard
  • Pozi head and wax lubricated for the easiest driving, pack of 1,500
  1. WoodSpur Pozidrive Wood Screw Assortment (1,500 Pieces)
Total:
£86.67 £72.22
The features that set WoodSpur apart...
Gold zinc plated steel finish screws with high resistance to corrosion. Suitable for interior use
in soft or hard wood, chipboard, OSB or MDF.
The head
Increasing the size of the head where it meets the body makes these screws much stronger. This minimises the risk of the head shearing under the final tightening torque.
The tip
The tip cuts as it penetrates and the initial portion of the thread engages immediately. The sharp point helps when placing the screw and prevents skating.
Pack of the most commonly used yellow zinc passivated plated wood screws with a self countersinking head. They have deep sharp threads that cut into the wood dividing the fibres rather than simply forcing their way through and a penetrating tip requiring no pilot hole or pre-drilling. Screws are heat treated to ensure they are hard and resistant to snapping. Lubricated with a wax coating to minimise heat and aid insertion. For use in soft or hard wood, MDF or chipboard. Precision Pozi drive heads. 1,500 screws in pack. The case measures: 320mm x 260mm x 55mm.
Pack contains:
3.5 x 16mm x 220
3.5 x 20mm x 220
3.5 x 30mm x 300
4 x 30mm x 300
4 x 40mm x 100
4 x 50mm x 120
5 x 50mm x 100
5 x 60mm x 60
5 x 70mm x 40
5 x 80mm x 40
4.60 41
