Chestnut Acrylic Lacquer
- Hardwearing, water based lacquer
- Dries to a very high gloss
- Apply with brush or roller
A hardwearing water based lacquer, a good alternative to solvent based products. It dries to a very high gloss. Whilst drying, the resin components cross-link to form a coating which is actually tougher than Melamine Lacquer. Apply with brush or roller, allowing two hours between coats. We recommend the use of acrylic sanding sealer first to give a smooth base on which to build the lacquer.
Application Method | Brush \ Rag or Cloth |
Clean Up | Water |
Coverage | 8 m² to 10 m² per litre |
Drying Time | 20 minutes |
Usage | Interior |
