Easy Wood Tools
Easy Wood Tools Full-Size Easy Turning™ Set 3-Piece
SKU: 109209
€390,00
  • Ideal for spindles, table legs, large bowls, platters etc
  • No need to sharpen;, simply rotate cutter to a fresh edge
  • Solid carbide replaceable tips keep an edge many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 8mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
The Easy Wood Tools Full‑Size Easy Turning™ Set 3‑Piece provides a complete solution for turning larger projects, including spindles, table legs, and large bowls, combining strength, reach, and control in one versatile set.
It includes the Full‑Size Easy Rougher™, Easy Finisher™, and Easy Detailer™, giving you everything needed to move from rapid material removal through shaping to fine detailing on bigger workpieces.
Each tool features a replaceable carbide cutter and a robust 12.7mm square section bar that sits flat and steady on the tool rest, making them easy to control and highly predictable in use.
The longer 406mm American Maple handles provide added leverage and balance, giving you greater control when working on larger blanks or deeper forms.
With no sharpening required, you can focus entirely on turning, rather than maintaining tools.
Working together as a complete system, each tool plays a distinct role. The Easy Rougher™ uses a square cutter to remove material quickly and efficiently, allowing you to establish shape with ease. The Easy Finisher™, fitted with a round cutter, refines curves, shapes hollows, and smooths surfaces ready for final finishing. The Easy Detailer™, with its diamond‑shaped cutter, creates crisp beads, coves, and fine decorative features.
When used parallel to the floor at centre height, the square bar keeps each tool stable on the rest, helping to minimise catches and snatches. This stability, combined with the added leverage of the full‑size handles, makes the set particularly effective when working on larger and heavier workpieces.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Set includes: Full‑Size Easy Rougher™, Easy Finisher™, Easy Detailer™
Cutter types: Square, round, and diamond carbide cutters
Bar profile: 12.7mm square section for stability on the tool rest
Handle length: 406mm
Overall length: 622mm
Handles: American Maple with copper ferrules
Use: Suitable for dry or green wood and acrylics
Negative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin, while also helping to produce a finer, smoother finish on timber during shaping and final cuts.
EAN Barcode 5052511133352
