Easy Wood Tools
Easy Wood Tools Mid-Size EASY ROUGHER™
SKU: 109253
€125,00
  • Versatile go‑to roughing tool for bowls, platters, boxes and spindles
  • Removes material quickly, cleanly and efficiently
  • No sharpening required - simply rotate the carbide cutter to a fresh edge
  • Solid carbide cutter keeps an edge many times longer than HSS
  • Suitable for turning dry or green wood, acrylics, and resin
  • 9.5mm sq section bar sits flat and steady on the tool rest for easy control
  • 350mm American maple handle, copper ferrule for strength and leverage
The Mid‑Size Easy Rougher™ is a carbide woodturning tool designed for rapid, controlled material removal when turning bowls, platters, boxes, spindles, and larger projects.
Offering increased reach and versatility over the Easy Start range, it is a reliable go‑to tool for turners looking to tackle a broader range of work with confidence.
Featuring a replaceable carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑Size Easy Rougher delivers excellent stability and easy control with no sharpening required.
The longer handle provides improved leverage and comfort, making it ideal for bowl and faceplate turning, while remaining intuitive and predictable for turners transitioning from smaller tools.
The Mid‑Size Easy Rougher removes material quickly, cleanly and efficiently, helping establish shape with minimal effort on larger blanks.
The square section bar ensures the tool remains flat and steady on the tool rest, and when used parallel to the floor at centre height, the risk of catches and snatches is virtually eliminated, supporting smooth, controlled roughing cuts.
With no sharpening needed, maintenance is simple - when the edge becomes dull, just loosen the fixing screw and rotate the cutter to a fresh edge.
Easy Wood Tools’ long‑lasting carbide cutters keep an edge many times longer than HSS and are suitable for turning dry or green wood, as well as acrylics.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
What you get
Square carbide cutter fitted as standard
Hex key for easy cutter rotation or replacement
350mm American maple handle with copper ferrule for added strength
Colour‑coded handle for easy identification within the Easy Wood Tools range
Specifications
Overall length: 533mm
Bar profile: 9.5mm square section
Optional upgrade
Negative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin materials, while also producing a finer, smoother finish on timber as skills develop.
Replacement Tip Ci2-SQ (109254)
EAN Barcode 5052511133376
