Crown Small Marking Gauges
- Made from solid hardwood with brass fittings
- 150mm(6") long stems
- 50mm(2") square heads
- Perfect for small or delicate work
- Three available - marking gauge, cutting gauge or combination screw slide mortice/marking gauge
These three small gauges are beautifully made from solid hardwood with brass fittings. The stems are 150mm(6") long and the heads are approximately 50mm(2") square. Used for small or delicate work where a full sized standard tool would be too cumbersome. Choose from a marking gauge, cutting gauge or combination screw slide mortice/marking gauge.
