Easy Inlay Metal Leaf Application Starter Kit
- Start adding decorative detail to your projects
- Everything you need to apply metal leaf
- Including easy to follow instructions
- Add a metallic gleam and glimmer to any woodworking project
The Easy Inlay Metal Leaf Application Starter Kit has everything you need to start gilding. Metal leaf adds a luxurious metallic gleam and glimmer to any woodworking or woodturning project. Easy Inlay has assembled this kit to give you everything you need to get started applying metal leaf. This handy kit includes: 2 x Sizing Liquid, 1 x 1" Application Brush, 1 X Mop Brush, 5 x Polishing Cloths.
To start gilding, simply apply a thin, even coat of gilding size adhesive with a soft brush or pad applicator to a sealed surface, allow it to dry to a light tack, then press metal leaf or flake into size. Remove loose skewing (bits) with the soft mop brush and lightly burnish with the polishing cloth. Seal with your favourite finish.
