Easy Wood Tools Micro EASY FINISHERâ„¢
109203
Special Price £62.29 £51.91 was £88.98 £74.15 Save £26.69 £22.24
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Friday 11th Jul
  • Use for small, fine detail or delicate turning projects
  • Finisher for coves, hollows, sweeping curves and final shaping
  • No need to sharpen;, simply rotate cutter to a fresh edge
  • Solid carbide tip keeps an edge many, many times longer than HSS
  • Use to turn dry or green wood, acrylics and resin
  • 8mm square section bar ensures the tool sits flat and steady
  • American Maple handle with copper ferrule for strength
Micro tools for miniature projects
If you have a small lathe and specialise in miniature projects, then these are the tools for you. With 6-inch handles, the Easy Wood Tools micro range is perfect for pen turning, miniatures and fine details.
  • Handles are made from one-of-a-kind grained American Maple and feature a copper ferrule for strength
  • All tools come with a fresh standard carbide cutter installed, and a hex key that fits the mounting screw
  • The range features three cutting types with colour coded handles to make your turning easy from start to finish
Micro Easy Rougher
Remove bulk material quickly and efficiently.
Micro Easy Finisher
For creating curves and for final shaping.
Micro Easy Detailer
For precision details - micro coves, beads, and finer details.
Why buy?
All tools come with a carbide cutter and hex key. These cutters retain their edge with no need for regular resharpening. When one edge does dull, simply flip the cutter and finally replace when needed. A range of optional cutters and replacement cutters are available too.
Easy to use
All Easy Wood Tools are held flat to the tool rest and parallel to the floor making them much easier to use than traditional tools.
Never sharpen again!
The premium grade carbide tipped cutters last at least ten times longer than HSS (High Speed Steel) before dulling. Meaning you can turn time and time again, with no need to sharpen.
Replace your cutters
When your edge finally dulls, simply replace it. All tool shafts are engraved with the corresponding engraved cutter number to make replacing cutters simple. See the range of cutters
Quality from end to tip
All carbide cutters feature the best grade carbide for lasting sharpness and a precision grind for a smooth and optimum edge for your turning.
  1. Easy Wood Tools Micro EASY FINISHER™
Total:
£218.04 £181.70
Easy Wood Micro Easy Tools are designed for small or finer detail turning projects such as pens or small ornaments or fine finials. Use the Easy Wood Micro Finisher for making coves, hollows, sweeping curves and final shaping. It comes fitted with a round tip and includes a hex key for the mounting screw. The 150mm handle is American Maple with a copper ferrule for strength (the tools have different coloured handles for easy recognition). The 8mm square section bar ensures the tool sits flat and steady on the tool rest. With the tool parallel to the floor and cutting at centre height the risk of catches and snatches is virtually eliminated. You don’t need to sharpen these tools. When an edge becomes dull you simply slacken the fixing screw and turn to a fresh edge. Easy Wood Tools’ carbide keeps an edge many, many times longer than HSS. These tools can be used to turn dry or green wood and acrylics.
Overall length of 235mm. The shaft is engraved with the corresponding carbide cutter reference number.
Easy Wood Tools are 100% made in the USA.
