EML Silver Steel
From £0.98 £0.82
  • British made, high carbon bright steel, precision ground
  • Guaranteed accuracy; 330mm lengths; readily machinable
  • Closely controlled analysis for consistent heat treatment results
Crusader Silver Steel is a high carbon bright steel, precision ground to very close tolerances. Close control of chemical analysis, particularly the chromium content, ensures optimum strength and hardenability and a consistent response to heat treatment. Crusader Silver Steel is supplied in the annealed condition and is readily machinable. All ends are individually deburred, which ensures safety during handling and protects other pieces from scratching. Silver steel pieces are individually dipped in a lanolin-based solution to guard against corrosion.
Length: 330mm
Tolerances: under 25mm dia + 0.000 and - 0.010mm, over 25mm dia and above + 0.000 and - 0.020mm
Heat Treatment: for maximum hardness (66 Rockwell C or 950 VPN) heat to 770°C - 790°C (1420°F - 1450°F). Soak until uniformly heated then quench in clean water or preferably 10% brine solution. The most satisfactory and efficient method is to heat in a salt bath and it is advisable to control the temperature carefully. The use of a pyrometer is recommended. If a muffle furnace is used, the atmosphere should be slightly reduced to minimise scaling and to avoid spots. Soak for a minimum of one hour at the following temperatures immediately after hardening:
Temperature Range Hardness
• 150°C (302°F) - 63/65 RC
• 200°C (392°F) - 60/62 RC
• 250°C (482°F) - 59/61 RC
• 300°C (572°F) - 55/57 RC
Annealing: heat to 760° - 780°C (1400° - 1470°F). Soak for one hour per 25mm of section and cool slowly in the furnace.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.50 6
