3 in 1 Pizza Cutter, Slicer & Server
110896
110896
- 3 in 1 pizza cutter and server
- Serrated edge and rolling cutter
- Stainless Steel, food safe and rustproof
Micro-Mesh Soft Touch Abrasive Pads 50 x 50mm - Mixed (Pkt 9)From £15.58 £12.98
Show more
Show less
Cut and serve your pizza with ease, with this handy 3 in 1 pizza cutter. Features a serrated edge for slicing as well as a razor-sharp rolling wheel for tackling crusts. The wide, flat platform lets you easily serve up slice, after slice, after slice. Stainless Steel construction makes this 3 in 1 cutter food safe, rust resistant and simple to clean. Easy to make on a 7mm mandrel or turn between centres.
Difficulty | Beginner |
Drill Bit Required | 15/32" |
EAN Barcode | 840229915903 |
Minimum Blank Size | 1-1/2” x 1-1/2” x 4” |
