Arbortech Sanding Pad For Power Carving Unit
- 100mm diameter with hook and loop facing
- Slightly flexible for contoured surfaces
This 100mm sanding pad for the Arbortech Power Carving Unit is slightly flexible, making it good for sanding medium to large projects and capable of moulding to slight contours. It has a hook and loop facing for rapid abrasive changing. Use the Sanding Pad in combination with the Chip Catcher and attach to a vacuum for wood dust control or with the Levelling Guide to achieve flat, smooth surfaces.
EAN Barcode | 9313478902419 |
