Axcaliber Metal Cutting Bandsaw Blades
From £12.68 £10.57
39 Reviews
  • 10tpi blades are made from high carbon stock
  • 14tpi blades are made from triple heat treated M42 stock for long life
  • Durable and will produce a straight, smooth cut
  • Manufactured at Axminster using advanced CNC machining
Get the best blade for your task
Axcaliber bandsaw blades are manufactured at Axminster using advanced CNC machining, high precision digital measuring equipment and specialised heat treatment facilities. Detailed quality checks are performed at each stage of manufacture using the most modern inspection equipment.
These blades are made for small metal cutting bandsaws, are durable and will produce a straight, smooth cut. The 10tpi blades are made from high carbon stock, whereas the 14tpi blades are made from triple heat treated M42 stock for long life.
British Made British Made
4.10 39
