Axminster Professional Quick Action Guide Rail Clamp - 160 x 60mm
- Spigot 11mm wide, 4mm thick, 60mm long
- Fits Festool FS, Makita, DeWALT and many other extruded guide rails
- Please check your guide rail prior to ordering
Titebond III Waterproof Wood Glue - 3.8litres (1 US Gall)From £69.98 £58.32
Axcaliber T-Slot Cutter for Track ClampsSpecial Price £15.78 £13.15 was £19.68 £16.40 Save £3.90 £3.25
See the entire range
This quick action clamp has a specially designed spigot to fit into the slot on the underside of a power tool guide rail. The spigot is compatible with the following guide rail systems, amongst others: Festool FS, Makita, Milwaukee, DeWalt, Kreg and Rigid. To be sure, please check the clamp slot in your guide rail prior to ordering. The spigot is 11mm wide by 4mm thick and 60mm long. Clamps supplied singly.
Owners of multi function workbenches can use the clamp as a hold-down simply by inserting the spigot into a dog hole. The single-handed operation leaves one hand free to steady the workpiece. The moving jaw has a resilient protective pad to prevent damage to delicate surfaces.
Clamp Throat Depth | 60 mm |
Clamping Capacity | 160 mm |
EAN Barcode | 5052511107995 |
