Axminster Professional Universal Clamp 10-48mm
105638
From £58.38 £48.65
1 Review
  • Buy 4 for £52.55 £43.79 each
  • Buy 8 for £49.62 £41.35 each
  • Buy 16 for £46.70 £38.92 each
Low Stock - Ready to dispatch
  • Problem-solving clamps for edging, carcasses, T-joints, corner joints, frames,
  • Easy to position and tighten, sold singly
  • Spring-loaded, eccentric cams for instant grip, range 10 to 48mm, depth 80mm
See the entire range
The more tasks a tool can perform the greater the value. These universal clamps help in tricky situations that usually require more specialised clamping solutions. The one-sided frame design solves problems when gluing edging, carcasses, T-joints, corner joints, frames, etc. You can apply and tighten them with one hand, leaving your other hand free to hold the work in position.
The spring-loaded, eccentric cams that form the jaws have a high-friction resilient rubber over-mould. This ensures a firm non-slip grip and prevents damage to the workpiece. As you apply pressure with the handle, the cam jaw grips ever tighter for an ever firmer hold. A swivelling plastic end cap on the screw protects the work.
Sold singly.
Grip range 10mm to 48mm, jaw depth 80mm.
Warranty Axminster Professional Clamps Lifetime Guarantee
4.00 1
