Axminster Workshop 102 Apron Plane
109568
Special Price £44.98 £37.48 was £74.98 £62.48 Save £30.00 £25.00
3 Reviews
In Stock - Ready to dispatch
  • A plane that fits naturally in the palm
  • Solid cast and polished brass cap
  • Micro-adjustable depth of cut for precision control
  • Handy size for fine trimming jobs
Ideal for fine trimming of end grain and flicking out chamfers...
Designed for frequent use, this plane fits comfortably in your palm and in your apron pocket.
Low angle
O1 steel blade for good edge retention. It is 30mm wide and 3mm thick and sits at 12.5 degrees.
Body
Solid cast body feels sturdy in your hand, feeling secure when in use.
Cut
Micro-adjustable depth of cut for precision control and low angle makes this plane ideal for general usage or end grain work.
Cap iron
Polished, solid brass cap ensures the plane is comfortable for your hand.
The Axminster Workshop 102 Apron plane is a vast improvement on the original Stanley first produced over 140 years ago. The depth of the cut is micro-adjustable using the knurled brass knob, allowing you to fine tune for removing that final whisker. The 30mm wide blade is O1 steel, for good edge retention.
Our 102 is designed to fit perfectly in a woodworker’s hand. The polished brass cap fits in your palm and the circular depression for your index finger makes holding and using the plane a real pleasure. The plane’s size means you can pop it in an apron pocket so it is always at hand, when it comes to trimming a sharp edge or a bit of fine tuning for a perfect fit. The plane has a nice solid feel to it with just the right amount of heft.
4.00 3
