Bosch C430 Delta Abrasive Mixed Pack 10
111687
111687
- High quality, resistant hook and loop back abrasives
- Suitable for use on wood, veneer and solid surfaces
- Pre-punched for efficient dust extraction
- Pack of 10 mixed abrasives
Show more
Show less
A range of high quality, resistant hook and loop back abrasives for use with most makes of Delta sander. Particularly suitable for use on wood, veneer and solid surfaces. Ideal for sanding varnishes on surfaces, sanding after wetting on particular materials, smoothing out feather edges and more. These abrasives can be used repeatedly due to their long-lasting material properties. Triangular - 93mm. 6 pre-punched holes for dust extraction.
Pack contains:
2 x 60G sheets
2 x 80G sheets
2 x 120G sheets
2 x 180G sheets
2 x 240G sheets
EAN Barcode | 3165140509497 |
Model | C430 |
