The Semi-PRO 2 System from Fuji Spray offers exceptional performance and versatility from an entry level HVLP spray system. Whether you’re a DIY-er or serious hobbyist, Fuji Spray has got you covered.
Whatever your application, the Fuji Spray Semi-PRO 2 will give you ultimate control, achieving a consistent and flawless finish.
Perfect for home, hobby and craft users
Powerful 1,400W 2-stage motor turbine
Lightweight and easy to use
Ergonomic spray gun handle offers comfort during long spraying sessions and is insulated to protect from heat
Gravity feed vs Suction feed
But the big question is, do you choose gravity or suction feed? The answer is usually down to personal preference, however, each has their own advantages.
Fuji Spray Semi-PRO 2 Gravity HVLP Spray System
With Fuji Spray M-Model 7002G Gravity Spray Gun and 400cc cup
Gravity fed guns rely on gravity, to feed the finish to the spray nozzle.
Good for smaller projects and touch up work
Are lighter and more manoeuvrable than suction type guns, great for inside cabinets or other fiddly tasks
Require less air pressure - making the gun more efficient, leading to less wastage and gives better control
Fuji Spray Semi-PRO 2 Suction HVLP Spray System
With Fuji Spray M-Model Suction Spray Gun and 1,000cc cup.
Suction feed guns can carry more fluid than gravity feed models
The Fuji Spray M-Series 7001 Suction Spray Gun has a non-bleed design with a fan control knob to adjust the spray pattern
They offer easy spraying with good coverage, and are suitable for a range of finishing applications
The Fuji Spray Semi-Pro2 HVLP spray system features a powerful 1,400W 2-stage motor turbine and comes complete with a Fuji Spray M-Model 7002G gravity spray gun. The turbine unit is in a sturdy steel cabinet complete with a grab handle and handy gun storage. The external air filters are easy to wash or change. The Fuji Spray Semi-Pro2 includes a 7.6m hose with Quick Connect Coupler and an Air Control Valve. This is a lightweight machine ideally suited to serious DIY, crafts or hobbies.
The Fuji Spray M-Model 7002G gravity spray gun has a 400cc cup. The spray gun has an ergonomically designed, insulated handle that is very comfortable in use and insulates well against the heat that can develop in the handle of an HVLP spray gun. This gravity feed gun, being lighter and more manoeuvrable than the suction type guns, is a good choice for smaller projects or cabinet interiors. It comes with an air cap set #3 (1.3mm) installed.
The Fuji Spray Semi-Pro2 HVLP spray system is supplied with a comprehensive user manual, viscosity cup, cleaning brush and wrench.
Note: When spraying thick high gloss paints, the required thinning can affect the final finish. In this case we recommend using a 4 or 5 stage turbine unit; such as the Fuji Mini-Mite 4 or 5 or A Fuji Q4 or Q5 unit.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
