JSP SpringFit™ Fold Flat Valved Respirator FFP3 (Pkt 10)
105266
From £34.98 £29.15
  5. Half Star
11 Reviews
  • Buy 10 for £31.49 £26.24 each
Low Stock - Ready to dispatch
  • Protection level FFP3
  • A better fitting mask for better protection
  • Internal structure results in an unrivalled secure fit
  • Structure maximises fit, comfort and performance
  • Typhoon™ valve reduces breathing resistance
  • Adjustable straps for a improved fit
  • Foam strip around the inside forms a better seal
  • Welded nosepiece improves the fit around the top
  • Compatible with safety glasses and goggles
  • Conforms to EN149:2009
The SpringFit™ fold flat disposable mask incorporates JSP’s Integrated Structural Comfort™. This takes the form of a unique endoskeleton structure inside the mask, resulting in an unrivalled secure fit. The structure maximises fit, comfort and performance. A better fitting mask is more likely to give you better protection. These SpringFit™ disposable masks feature the Typhoon™ valve, which reduces breathing resistance, heat and moisture build-up. The valve is unaffected by any moisture, and therefore can be used with the same performance under very low temperatures.
These masks are extremely comfortable; the straps are adjustable for a comfortable fit. A foam strip around the inside of the mask adds to the comfort and helps form a better seal. The welded nosepiece improves the fit around the top of the mask. The design of the SpringFit™ mask offers greater compatibility with safety glasses and goggles. Protection level FFP3.
4.50 11
