Makita 4350CT Jigsaw
702331
702331
- Exceptionally low vibration
- 135mm maximum depth of cut
- Tool free blade change
- Integral blower
- Variable speed setting at rear of tool
- Soft start electronic speed control
- 3 stage pendulum cutting action
Show more
Show less
The exceptionally low vibration of this model ensures that nearly all power is used in the cutting process and not wasted. This jigsaw also has a soft start and constant speed control along with quick and simple blade change that requires no tools. Supplied in carrying case complete with dust nozzle, baseplate cover, anti-splinter device and jigsaw blade set.
Blower | Yes |
Corded or Cordless | Corded |
Dust Extraction | Yes |
Max Depth of Cut Steel | 10mm |
Max Depth of Cut Wood | 135mm |
Model | 4350CT |
Nett Weight | 2.4kg |
Pendulum Action | 3 |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 95 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 84 dB(A) [3.0 dB] |
Stroke Length | 26mm |
Stroke Rate | 800 - 2,800/min |
Tilting Base | Yes |
Vibration Cutting Sheet Metal [Uncertainty K] | 4.5 m/s² [1.5 m/s²] |
Vibration Cutting Wood [Uncertainty K] | 8.0 m/s² [1.5 m/s²] |
Voltage | 230 V |
