Makita RT0702CX2 Router/Trimmer (1/4")
108667
From £228.98 £190.82
  5. Half Star
7 Reviews
  • One motor with 3 different bases: plunge, trimming and bevel
  • Host of small routing and trimming tasks in the workshop or on site
  • Motor is fitted with variable speed control, soft start
  • Can be quickly locked into the required base
  • Plunge base: 2 solid grip handles, quick and fine height adjuster
  • Trimming base for single handed use, fitted with bearing guide
  • Bevel base can tilt and be locked at a required angle
  • Trimming guide with roller bearing for curved edge work
  • The machine is also supplied with a 1/4"collet, side fence, 16mm & 10mm template guides, side grip, dust extraction shrouds, 13 and 22mm wrenches and tool bag.
Compact router trimmer that combines one motor with different bases. This machine is great for a host of small routing and trimming tasks in the workshop or on site. The motor is fitted with variable speed control and has a soft start. It can be quickly interchanged and locked into the required base. This kit comes complete with three bases; Plunge, Trimming and Bevel.
Plunge base: turns the machine into a plunge router with 2 solid grip handles, a height adjuster with fine adjustment and a stepped turret for repetitive depth setting. The side fence fits left or right. Easy to control, suitable for decorative edge working as well as small mortices and grooves.
Trimming base: this small 90mm round base turns the machine into a trimmer for single handed use. Use with or without the height adjustable bearing guide for cutters without bearings, rolling on the curve for a fine cut. A trimmer guide is supplied for curved work or the side fence can be used for straight work.
Bevel base: a small square 90mm base that can tilt and be locked at a required angle (45°-0°-30°), allows for more scope when profiling and jointing.
In addition the machine is supplied with a 1/4" collet (The RT0702 will accept a 3/8" collet not supplied), Side fence, Trimmer guide, 16mm & 10mm template guides, side grip handle (can replace right plunge base handle), dust extraction set, 13 and 22mm wrenches and tool bag.
Note: This router is fitted with an Anti Restart Safety Switch and is incompatible with a seperate external NVR switch.
4.70 7
