Miller Birch Dowel Joinery Kits
From £49.48 £41.23
  • Produce strong, secure joints with minimum fuss
  • Simple method of producing long lasting joints
  • Kits available in three sizes
  • Birch Dowels
  • Self-capping
  • Ribs along length allow glue to adhere to material and dowel
  • Drill bit supplied in initial starter pack
Miller Dowel has revolutionised the speed and ease of making glued joints for your furniture and cabinets. These joints are quick, easy and precise, and sacrifice nothing in the quality of the joint produced. Available in three sizes, the starter packs are complete with a unique stepped drill bit for an exact fit and a supply of the Birch dowels.
Mini Kit (6.5 diam. x 41.5) for timber 12 - 14mm thick.
Standard Kit '1X' (10.5 diam. x 70mm) for timber 16 - 25mm thick.
Large Kit '2X' (12.8 diam. x 90mm) for timber up to 32mm thick.
Further packs of dowels are available for each size in Birch, Oak or Walnut.
The innovative stepped and ribbed form of these dowels (or maybe they should be called wooden nails) keeps the glue where you want it, in the joint, without the problem of compression experienced in ordinary dowel joints. The ribs grip the sides of the stepped pockets as they swell with the glue to lock them in place.
The procedure is simple:
Clamp or hold together the pieces to be joined.
Drill the stepped hole with the Miller TruFit bit for the selected dowel size.
Spread a thin layer of glue (Titebond II is recommended) on the ribbed section.
Tap the dowel into the hole until fully seated.
Trim off and sand level - Miller dowels are self capping - so job done!
Please remember - good and accurate surface preparation of the mating surfaces is essential to the strength and neatness of the joint.
TOP TIP for an interesting effect, use a Miller Dowel which contrasts with the host timber.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.80 30
