Mame Doraku Miniature Dozuki Saw
109824
Special Price £15.83 £13.19 was £29.98 £24.98 Save £14.15 £11.79
  4. Empty Star
1 Review
In Stock - Ready to dispatch
  • Small, compact saw ideal for precision work
  • Fine blade that cuts smoothly and effortlessly
  • Features a spine along the back to support from blade to tip
  • Cuts on the pull stroke, achieving a clean finish
  • Lightweight Paulownia wood handle
This miniature Dozuki saw is ideal for cutting small portions of wood and other precision work. It's compact, so perfect for extremely fine furniture restoration, plus luthiers, cabinet and model makers who require a very fine blade for precision work. Both the blade thickness and pitch is just 0.1mm, allowing you to cut intricately with great ease. The spine along the back supports the blade to the tip and helps to carry the blade almost effortlessly down the cut, ensuring you will achieve a precise, fine finish. Cutting on the 'pull' stroke, the saw only requires the lightest pull as it works in tension, to achieve a smooth cut.
The handle is made from Paulownia wood so is lightweight, yet sturdy.
The overall length is 155mm. The blade length is 55mm.
3.00 1
