Miniature Ryoba Saw
Miniature Ryoba Saw
- Small, compact saw ideal for precision work
- Double-edged saw for rip and crosscuts
- Fine blade that cuts smoothly and effortlessly
- Cuts on the pull stroke achieving a clean finish
- Lightweight Paulownia wood handle
This miniature Ryoba saw is ideal for close-up, intricate work. The double-edged saw has two different tooth patterns on either side of the blade; rip teeth on one side and cross cut teeth on the other, allowing you to carry out both cuts with ease. Both the blade thickness and pitch is just 0.1mm so you can cut accurately with great ease. It's compact and small; perfect for extremely fine furniture restoration, plus luthiers, cabinet and model makers who require a very fine blade for precision work. Cutting on the 'pull' stroke, this Ryoba saw only requires the lightest pull as it works in tension to achieve a smooth cut.
The handle is made from Paulownia wood so is lightweight, yet sturdy.
The overall length is 155mm. The blade length is 60mm.
