Miniature Kataba Saw
109826
From £22.18 £18.48
  3. Empty Star
  4. Empty Star
1 Review
In Stock - Ready to dispatch
  • Small, compact saw ideal for precision work
  • Fine blade that cuts smoothly and effortlessly
  • Backless to allow for deeper cuts
  • Cuts on the pull stroke achieving a clean finish
  • Lightweight Paulownia wood handle
This miniature Kataba saw is ideal for precision woodwork. The backless feature of the saw allows for deeper cuts to be made as it glides all the way through the material, resulting in a clean finish. The blade thickness is 0.2mm, with the pitch being just 0.1mm, allowing you to cut intricately with great ease. It's compact and small; perfect for extremely fine furniture restoration, plus luthiers, cabinet and model makers who require a very fine blade for precision work. Cutting on the 'pull' stroke, the saw only requires the lightest pull as it works in tension to achieve a smooth cut.
The handle is made from Paulownia wood so is lightweight, yet sturdy.
The overall length is 155mm. The blade length is 60mm.
2.00 1
