PEANUT® 2 Short Connectors
AX1042649
AX1042649
- Ideal for mitre joints and attaching drawer fronts
- Self-clamping invisible connectors, create an incredibly strong joint
- Pulls the joint together from the inside
- Can be taken apart and reassembled many times
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Show more
Show less
PEANUT® 2 Short connectors are super tough glass-reinforced nylon. Use these in conjunction with the PEANUT® router jig or PEANUT® Mini Jig to produce strong, quick and highly accurate 45°, 90°, joints, attaching drawer fronts and face-to-face joints in solid wood or sheet materials. The connector design produces an incredibly strong joint.
The PEANUT® 2 Short connectors are self-clamping and pull the joint together from the inside. The result is an invisible connection that can be taken apart and reassembled many times.
#AxminsterTools
