Robust Mini Tool Rests
- Hardened steel bar on top edge will not dent or nick
- Robust; solid steel construction
- For all lathes with 16mm (5/8") tool post diameter
Explore the Robust Tool Rest range
Robust by name and robust by nature, these tool rests offer superb stability with a hard wearing, solid steel bar that provides a smooth turning experience.
Key features
Made from solid steel for strength, stability and smooth support.
A range of diameters, heights and lengths to suit a variety of lathes.
Stay close to your work with a tight radius - more control, less chance of knicks.
A comfortable fit whether you use a overhand or underhand grip.
Which rest do I need?
With a wide range of tool rests to suit a host of turning projects, explore our Robust Tools Rests and discover which is the right fit for you and your lathe.
Robust Mini tool rests have 16mm (5/8") tool posts offering all the benefits of larger Robust rests to owners of smaller lathes such as the Axminster Craft AC305WL and AC240WL. These rests feature a hardened steel rod as the tool bearing surface that provides smooth tool transition and will never ding, nick or need filing. Your tools will glide effortlessly across the rod even after years of turning. Your hand fits comfortably in the radius of the rest, whether you use an overhand or underhand grip. You can get the rest close to the action for maximum tool support whether below or above centre height.
