Stanley FatMax® Tradelift™
111714
From £116.41 £97.01
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Lifting force of 150kg; lifting capacity of 220mm
  • Push-down lever mechanism for effortless lifting
  • Incremental lowering: 2.5mm per toggle for fine adjustments
The Stanley FatMax® Tradelift™ is a versatile, one-handed tool for lifting, holding, and levelling heavy loads with ease. The Tradelift™ uses a push down lever mechanism for smooth lifting, which makes it easy to apply pressure when lifting heavier items. Its very capable when it comes to lifting: it has a lifting force of up to 150kg, a lifting capacity of 7-220mm and lifts 8mm per stroke. As well as effortless lifting, the Stanley Tradelift™ offers incremental lowering of up to 2.5mm per toggle - perfect for fine adjustments when levelling. Another useful feature of note is the full release button: this essential button is recessed for safety, to avoid accidental activation of the full release. The large base plate has an angled edge to easily slide under objects and four countersunk screw holes to anchor the lift for stability.
Whether you’re a professional tradesperson or a DIY enthusiast, the STANLEY® FatMax® TradeLift™ is a reliable companion, providing you with a useful extra hand on site, in the workshop or at home. It's also possible to operate this with your foot for truly hands-free lifting. The Tradelift™ is ideal for kitchen, floor, door and window fitting, carpentry, joinery, drywall and general building. Possible uses include but aren't limited to: lifting and levelling kitchen units, nudging heavy machinery into place, holding doors for fitting. Safe and easy to use, the TradeLift™ will reduce the risk of injury and accidents when levelling and lifting.
