The Ultimate Router Base Template Guide Bushing
109975
From £12.38 £10.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Designed for use with The Ultimate Router Base System
  • 1.1/2" OD fits onto any 1" OD template guide
  • Best used for curved joinery on hardwood table edges
  • Use with a template and 1/2" router to create a perfectly matched cutting seam
  • Exclusive to Axminster Tools in the UK
The Ultimate Router Base Template Bushing is a great add on to The Ultimate Router Base. The 1.1/2" OD fits onto any standard 1" OD template guide. When used with a template and 1/2" router bit, the bit can be exactly positioned to either side of a cutting seam to create a perfectly matched seam. It is best used for curved joinery on hardwood table edges.
Designed for use with The Ultimate Router Base System. Exclusive to Axminster Tools in the UK, The Ultimate Router Base System will be the only router base you ever need.
